Uploaded Jan. 15, 2017
This paper will serve to unite several fundamental parameters involving the fine structure constant, the hyperfine frequency of the hydrogen atom, the Golden Ratio, the electrogravitational frequency of my own theory of, "Electrogravitation As A Unified Field Theory", as well as the 60 Hz field as a fundamental constant in nature with the geometry built into the design of the Great Pyramid at Giza in Egypt.
Respectfully, Jerry E. Bayles, (Quantum Mechanic) URL: electrogravity.com
