Half-Sin pulse shapping
NorbertoBarroca
I'm trying to implement an Half Sin Pulse shapping filter like the one shown bellow.
My input values are given by:
My filter function is:
However when I make the convolution between the input values and the filter the result is no the expected I alway have zero can someone help me?
Message was edited by: Norberto Barroca
Hi Norberto
Would recommend change to definition of pulse for clarity, at 2TC 4TC etc output is defined by 2nd condition but mathematically it could be either 1 or -1.
The main problem however seems to be the way mathcad divides the period of the integral.
It is reaching a limit at which it cannot resolve the information & everything collapses to the 0 result that you get.
Not too useful in your case where you actually want to integrate between infinities.
Example sheet gives same output for I =100, 455 & 460 *Tc (3.1830988618x10^-7s) but 0s for the 461* Tc case.
It might be that for a different system (eg not mathcad 12 ...) it will run to different limits, I'll be interested to hear comments about this.
Note that I've tried changing TOL & CTOL values - does improve the accuracy of the result given but not the level at which it 'breaks' & gives a zero answer.
Andy
