OK, I successfully imported .csv file into Mathcad Prime using READCSV.
My .csv file contains a table, one column are dates and another are numbers, there also a spurious empty columns.
I have no idea how to deal with dates, but my primary interest is second column with numbers.
But problem is, Prime interprets the whole csv table as matrix of string values, despite of numbers on second column are well-formed.
I tried str2num function, but it refuses to do the job, probably due non-scalar input. How do I pre-process this column to finally start my real calculations?
As a bound, could anyone please advise on dates in the following format: "2010-06-26",...
Thank you.
Use the vectorize operator
You will have to use Mathcad's string functions to convert that to three numbers, but then to use that date see here: Date Calendar and Time functions.mcd - PTC Community
