How to change header/foot dimensions in a template?
Endymion
I'd like to take an existing template and change the size of the headers and footers in it. I can't figure out how to do this (I can't click on the header/footer boundary and resize). Anyone know the procedure?
BTW, it would be nice if you could add a watermark to the document.
Thanks in advance,
John
As ridiculous as it may sound, the "modern" Prime is simply not able to!
We have no ability to set the page margins either, or just a custom grid size. Sad thing.
That's very unfortunate. Thanks for the help.
John
