can you convert now mathcad format xmcd into mcdx, please
Hello. Can someone help me to convert this file to MCDX, please? Thank you very much !
What version of Prime are you using?
PTC Mathcad Prime 7.0.0.0--
Then you should be able to convert the worksheet yourself, using the converter interface built into Prime 7:
But I see that Vladimir was kind enough to convert it to Prime 3.1. Your Prime 7 should be able to read that file.
That's because Mathcad 15 can read Files from all the way down to Mathcad 1 (Not Prime...! ).
See also here.
