It is rather easy to copy formula from Mathcad to word. Copy from word back to Mathcad ended at a photo or picture?
Is there anyway to make copying word formula to Mathcad working?
Also tried formula using Mathml, word does accept that. But copy mathml into Mathcad ended showing long list of mathml code itself.
As word can accept formula copied from Mathcad, Mathcad must using certain standard code (e.g. Mathml) to store/display all formular's.
Anybody may advise what kind code Mathcad using for store/display all formula?
hanks a lot.
In short: there is no way.
When you copy a math region from Mathcad (I assume you are using Mathcad 15) to word the result depends upon how you highlight that region, If you don't click inside the region but just fence it, you will end up in Word with a picture.
If you click in the region , highlight the part you want to be copied then what you end up with is an embedded Mathcad Region in Word, Its Mathcad's dll displaying that forumula, not Word. If you double click in Word on that object, its Mathcad coming up to edit that region.
