I have a license for MC15 that was purchased when MC14 was the current version. I recently upgraded my maintena ce agreement, but did NOT get a new Sales Order number. When I enter my original Sales Order Number I getn only the option to down,oad MC14. How to I get a version of MC15 for Win 7, 64-bit?
Thanks.
Vic Roberts
I found MC15 on the PCT support site, dowaloaded the ZIP file and tried to install it on this Windows 7 machine, but the installation failed. The date code of the file I tried to install was M005. As far as I can tell, there is not a separate version of MC15 for Windows 7, Can anyone confirm that?
Try logging the issue at https://www.ptc.com/appserver/cs/mathcad_case_logger/options"
Mike
Mike,
Thanks for your answer.
The issue was a missing MSXML file. MS says the file is not needed for Windows 7 so I was not sure if I needed to go get it. I then decided to try to install MC14, and that worked because it automatically installs the MSXML file. I now think that I can install MC15, but MC14 is OK for now.
Vic Roberts
