it`s Parabolic cylinder function - Wikipedia, the free encyclopedia
I need to input D of order (-0.5). Thanks
From your page
How far do we have to chase this and how much is it worth?
You need to do more work than you have before I'll do any more. Let's see how much your Mathcad sheet has gotten!
I replaced function for http://dic.academic.ru/pictures/enc_mathematics/041703-49.jpg in attached file but the result which I got isn`t good
The Mathcad 15 does not have emdedded function D, does it?
I added formula with function K but I don`t understand how to input negative argument D in the formula replacing D?
