I am creating a simple 2D plot, where I want to reverse the y-axis to be shown downward. Prime 3.1 sheet attached.
In MathCAD Prime 3.1 -> How is it possible to inverse the y-axis to increase downward. Hence - top value on y-axis is 0 and bottom value is 500?
Thank you in advance!
Anders
In Prime, you can't do that. Just one of the very many limitations of Prime.
Hi Richard.
Thanks for the quick response. I did not know this, since I am quite new to "Prime" version. I heard from a co-worker that Prime 4.0 (coming in fall) will be expanded regarding plotting.. Hopefully this will help..
Anders
Anders Albertsen wrote:
Hi Richard.
Anders
Expanded, "to the capabilities of Mathcad 15."
Which has been complained about since it was released, and previous versions before that.
You do sooner to turn the computer upside down .....
Maybe it helps to live in Australia!
One solution
