How to make combo box show matrix value after evaluation
OM_10154742
6-Contributor
Hi Everyone,
I am sure I am not the first to ask but could not find any information on this issue. How can I have mathcad to show the matrix value after having the variable in combo box. Also, is there any option wherin prime will open all the worksheets in draft view?
ttokoro's response:
ttokoro
20-Turquoise
(To:OM_10154742)
OM_10154742
6-Contributor
(To:ttokoro)
How do I insert this is combo box to get it evaluated?
ttokoro's response:
Thank you so much for the informatio0n. I was wondering if I can open all the documents in draft view. Is that possible?
(To:OM_10154742)
There is no such option.
You have to switch to draft mode after opening each document.
Note that you can use a single click for that, in the lower right corner:
