could someone advise how to interconnect external data with spline points?
I generate coordinates in my external program .I use matlab now but can write code in anything. I want to drive spline points with this coordinates. I know I can save the coordinates to file and load in creo during editing the spline but this is not what I need. I would like at least the creo to read the file automatically during regeneration. Another possibility is to create program in mathcad and exchange data with parameters. There is problem the number of points change. Is it possible to use the spline from mathcad as geometry in creo?
Are there any other ideas?
(in Creo 3)
Thanks, best regards
michal
