How to read CSV files one at every time using uigetfile and apply a set of formulae
jrodriguez-9
Hi, I have several CSV files that contain 10,000 rows by 16 columns in a .CSV generated file as seen in the attachment. I want to execute some formulae on these data so that I can open it up and be able to run the formulae for each CSV file. How can I make this file to work?
Originally I had to convert CSV file to xlsx and then read it as follows.
[num21 txt21 numtxt21]=xlsread('R21_08S','B2:Q10001');
However this is too tedious and I would rather read it as:
[fNameDatai,pathNameData]=uigetfile('*.csv', 'Select the DATA file','Multiselect','on');
if ~iscell(fNameDatai),fNameData{1}=fNameDatai;else fNameData=fNameDatai;end
so that I don't have to convert CSV file to xslx and be able to just select the rows and columns I need.
(To:jrodriguez-9)
The syntax you show does not appear to be Mathcad (nor Prime). Are you using the API?
Why don't you just read the file using the READCSV() function into a matrix. Using Mathcad/Prime matrix operations you can select any rows and/or columns to work with.
xlsread??
Could it be you are confusing "Matlab" with "Mathcad"?
