Identifying coefficients, and storing them as variables
tlutze
I seem to have worn the internet thin, and have scoured posts here aswell and have not found what i'm looking for. i might have misset it, if so i apologice. Also, please excuse my english.
So what i'm looking for is a way to have mathcad prime look at an equation and store coefficients as variables - maybe by comparing the equation to a "mask". please take a look at the attached file to see what i'm talking about.
Thank you in advance
/Tonni
Fred_Kohlhepp
23-Emerald I
(To:tlutze)
If you input the equation in the right way, you can have the coefficients as a vector:
So this can be made to work with polynomials.  How would you get an equation without typing it in?
10 REPLIES 10
Fred_Kohlhepp
23-Emerald I
(To:tlutze)
(To:tlutze)
You can do this (in Mathcad 11, something similar should work in Prime:
But this fails in Mathcad 11, because the coeffs symbolic instruction expects the expression to be a polynomial that is expressed in th argument of coeffs:
Maybe by combining the results it could be made to work...
Pretty cumbersome:
Then there's this:
or, reversing orders:
And this we might be able to use:
And finally:
Pretty good stuff!
Wouldn't have thought of that.
24-Ruby V
(To:tlutze)
I also can't think of anything else than what Luc already had shown:
[EDIT: In the meantime Fred had proved that its possible to do using a cool two step method.]
I guess it could be possible to tun those calculations into a program in Versions of Mathcad from 15 down but this sure is not possible to do in Prime as it does not allow symbolic calculations inside of a program.
Cascading also shows limitations:
but we could at least do something like
BTW, here's some kind of the reverse direction:
tlutze
(To:tlutze)
Oh goodness, so many answers - i see i have some stuff to experiment with. Thanks
I'll look into each answer to see which best suits my needs and get back to you.
/Tonni
tlutze
(To:tlutze)
Sorry took me some time to get back, with some fiddling i were able to make use of most of the answers. so Thank you all!
Now the dilemma is the points, since i could use most, i'm going to assign them to the first answer.
Thanx again.
/Tonni
