Is there a singularity in this expression ? Need help with an explanation. How to correct this expression ?
lvl107
20-Turquoise
Hello Everybody.
Thank you in advance.
Best Regards.
RichardJ
(To:lvl107)
If you symbolically evaluate the inner two sums you will see that MuPad gives an expression that contains Gamma(1-j). That means when j=1 you have Gamma(0), which is your singularity.
RichardJ
(To:lvl107)
