Literal Subscript in middle of Variable
ptc-2712635
Hey, I found a MathCAD document (as pdf) in which a chemical reaction and their forming and reaction enthalpy is calculated. As you can see (attachment) the variables have an index within the variable which is used to calculate. Does anyone know how to create variables similar to this example? I appreciate any suggestions. P.S: I use MathCad 14 M020.
RichardJ
(To:ptc-2712635)
I think that must have been done with a specific font. It looks like T0 is the "normal" level of the font. The 1, 2, or 3 to the right of the T0 is either a literal or a vector subscript; I think a literal subscript (although it's hard to tell from a pdf). The small B or R are at the same level as the T0, whereas the delta is raised slightly. The h with a bar over it is also raised slightly, and the symbol to the right of that is obviously raised a lot. The only way to get something like this is with a special font. Richard
