Here I compared annual maximum flows to see how well they fit a log-normal distribution. What the user will need to do is download both the Mathcad file and the data set, then read in the data set.
Dixie,
You forgot to attach the text file of data ("Pearl River near Bogalusa.txt") together with the Mathcad worksheet:
No, I think there is a problem in transferring data tables to the PTC website. I opened a data table in Mathcad, copied the data to it and saved it in the file. It is on my system and works well. When I upload the file to the PTC site the data is apparently removed from the Table. Note that the external read for the file is disabled, I knew that would not work.
Now all works fine. And here we can use a relative file path (option "Use relative file path" in component properties):
