MathCAD 14 licensing via AnyConnect
edeklerk
Has anyone tried to setup Mathcad 14 licensing via AnyConnect? I'm unsure what additional ports need to be open (ports 7788 and 1074 are already open) for the licensing to work correctly. Any help/advice greatly appreciated.
Edmee de Klerk
Application Support Analyst
CGI
Hi Edmee,
You can ask about it at PTC's tech support by using "Mathcad Support Center":
http://blogs.ptc.com/2011/09/22/how-to-use-the-brand-new-online-mathcad-support-center/
