MathCad 14 won't eliminate negative numbers
ptc-4254605
"assume, x>0" is not removing the negative solutions in Solver. I'd like to know what the correct syntax is.
I'd also like to know how to list only real solutions. The manual says "assume, x=real", but MathCad 14 will not take this.
File attached as MathCad 14 file.
Jeff Corkern
Consider the following as a statement of logic, and rank it as "True" or "False":
"If people possess immortal souls, it should be possible to logically deduce this by objective analysis of their actions."
http://www.theninepointfivetheses.blogspot.com
Sometimes you can get around these problems
