I am working on this worksheet, and I cannot get Mathcad to plot my equation. I get the following error: "Plotting Failed. Replace complex values and NaNs by real numbers."
I am not using any complex values and I shouldn't have any NaNs unless their is a syntax issue.
I have looked through many resources, and I haven't found a solution to this seemingly simple problem.
Thanks in advance,
Charlie
As Mike already pointed out you have some unit problems in your gain function.
Have you ever evaluated gain() for a sibgle value of s? Sure not, so try it now.
The first unit mismatch is highlighted in the picture below. The fraction yield Ohm but the summand 1 is unitless.
Next problem may be that the green summand yields 1/sec^2 and so should the first summand.
I think the problem is with your gains function.
Break it down and change the unit compatibility.
