On 3/3/2009 12:56:19 PM, ColinCWare wrote:
>Thanks Eden, Philip, and
>Stuart,
>Your help got me off to
>resolving my question, which
>summerized is: How does
>Mathcad select the dimensions
>to display following a
>calculation involving a
>collection of properties?
>I work mostly in
>electromechanics. Calculations
>in these dimensions sometimes
>include "coul" Coulomb. The
>dimensions of coul are not
>displayed; henry, weber,
>farad, stokes, poise, joule,
>watt, and many other property
>dimensions are displayed.
>coul is the response to insert
>the unit of charge into a
>formula to be calculated. But
>charge does not have a
>dimension; it is a pure number
>of electrons or protons that
>make up the charge.
>volt/ohm = coul/sec. So what
>is a coul?
>Colin C eagle1@eaglmall.com
Coulomb IS the unit of charge, so an electron has 1.602*10
-19 coulombs of charge.
Since volt/ohm is current in amperes, it can be correctly presented as coulomb/second, although, per NIST, coulomb should probably be an ampere*second:
http://physics.nist.gov/cuu/Units/ampere.htmlTTFN,
Eden
