I'm aware that Mathcad Prime can communicate with Creo parametric, although I have tried it yet. I'm wondering how far I can take this. If I use Mathcad to parametrically build a component in Creo, can I also automatically apply boundary conditions to that model for use in Creo Simulate FEA? I'd really only need pressures on areas and some displacement constraints.
(I'm not set up to experiment myself yet, so I'm asking to get some background on what's possible - to justify getting setup and then spending time streamlining the design process.)
Thanks.
Please check the following videos:
"Creo Parametric 2.0 integration with Mathcad Prime 3.0": Creo Parametric 2.0 integration with Mathcad Prime... - PTC Community
"Creo Parametric and Mathcad Prime 1.0 Integration (Transmission Shaft)": Creo Parametric and Mathcad Prime 1.0 Integration ... - PTC Community
And here at "PTC University Learning Exchange": integration | PTC Learning Connector
