Simple question here:
Is there any way to return a row from a matrix in Mathcad 15? Of course, there's a matrix column function, and there is a matrix row function in Prime, but I have been working in 15 for a while on a worksheet and would rather not re-create it (converter isn't recognizing 15 on my computer and therefore won't work).
Thanks.
Just transpose and use the column operator:
Not sure why I didn't think of that. Perfect, thank you!
In Mathcad Prime
