So, I have attached my worksheet. The thing I need to do is plot each column of S1 (may be 1 or 2) as y-axis and then plot i (which is basically the length of each column). But for some reason I am unable to do so. Can you guyz help me with that? i am a NOOB in the field of Mathcad.
thansk
What values would you like to see at the abscissa (x-axis)? Numbers from 0 to 1023? or the column 0?
So the attached sheet should help.
The problem with your approach is that you can't plot a vector over a range. You have to turn the range into a vector first.
