Opening Mathcad 15 in 14
OpticGuy
Hi guys, I am trying to find out if I open a worksheet in Mathcad 15, can I use the same worksheet in Mathcad 14? Cause at home I have ver 15 and in Uni its ver 14.
Please advice.
StuartBruff
23-Emerald II
(To:OpticGuy)
Please advice.
You can open any version of worksheet in M15.
To ensure you can read a worksheet in an earlier version, go to the File menu, select Save As and choose the appropriate version from the 'Save As Type' drop-down (it might be wise to add the version number to the filename in case there are any M15 subtleties that are lost in translation, although I save the majority of my worksheets in M11 format without encountering many problems).
Stuart
You can open in MC 14 files created/edited in Mathcad 14.
Thanks a lot Valery!
StuartBruff
23-Emerald II
(To:OpticGuy)
Please advice.
Stuart
Thanks StuartBruff.!!
