PIN diode PI pad_curve fitting
ptc-1218903
In the attached sheet,
1. I am calculating the series and shunt resistor values of a PI pad.
2. The current vs resistance of a PIN diode is calculated.
Planning to replace the resistors of the pi pad with the PIN diode.
How to calculate the required diode current to produce the Sh_r(A_dB) and Se_R(A_dB) resistance?
Want to create an equation for Current vs it's resistance.
Appreciate your help.
Leyo
Your work sheet is restricted to users of above Mathcad 11.
"can't open the sheet".
jmG
To find Id, use find.
Note that MC11 format loses the secondary y axes.
__________________
� � � � Tom Gutman
