Parametrized solve block with pdesolve
npouladi
Dear PTC Community,
I am trying to solve one dimensional heat conduction in a hollow cylinder (for example a pipe) with heat convection both from the inside and outside.
Is there a way to use parametrized solve block with pdesolve? I want to be able to use the solve block for different values of Ti and hi, in a for-loop.
I appreciate your advice.
Thanks in advance  🙂
Yes, there is a way and fortunately is easy and straightforward:
Great help, thank you very much 🙂
