Partial and ordinary derivatives: not working properly
RosanelladC
I'm working on partial differentiation and I need to differentiate partially and ordinarily to then carry out a chain rule and check my manual workings as I go along. But for some strange reason Mathcad keeps returning a null (0) for a 1st-order derivative and not differentiating partially for d/dy displaying a warning (i.e. f(x,y) displays in red).
Any ideas?
Please don't worry abouot it.
The question is very relevant to the section that you posted in & the only thing that will occasion a strongly worded response is posting the same question in multiple forums
Andy
Main problems are the use of the vector index instead of using the literal index and that you tried to take the derivative of a function x(t) with respect to x rather than wrt t.
Hope the attached sheet will help.
Hi Rosanella,
I'm not sure how you typed the equations that you have:
I guess that it was "f[x:=" which would try to address element xof the array f to store the result.
If you change this to f.x to make it a simple subscript showing the diferential relation ,
You then need to add "(x,y)" to allow the numeric processor to understand that the variable x & y are still parameters.
Giving :
Andy
Thank you Werner for pointing out my error in dx/dt.
Thank you both for f dot x (I was not aware of that, but I don't see why the Superscript icon shouldn't be the same as f dot x. Are Superscripts used only for writing text within a text region?)
>Hi Rosanella,
I've simply used the Superscript at the top.
Basically, what I'm trying to achieve is
given a function f(x,y) , 1) partially differentiate it ,to obtain df/dx and df/dy
2) set z = f(x,y) and dz/dx = df/dx , dz/dy = df/dy
3) use the chain rule given x(t) and y(t)
dz/dt = dz/dx * dx/dt + dz/dy * dy/dt
By the way, the option of displaying dz/dx and dz/dy as partial derivative does not show on the menu by right-clicking on each of them.
PS I've already done the calculations manually. But I'd like to check my workings are correct.
I guess those super- subscripts at the menu line were supposed to be used for text regions primarily, but they work for math regions as well. The superscript is exponentialisation as supposed, but the subscript is, when used in a math region, the vector/matrix element selector. See this example. a is 3 element vector and as by default the numbering of elements begins with 0 (controlled by system variable ORIGIN) you acces the second element with vector index 1. You obtain this by using the subscript from the formatting toolbar, but you may also use the matrix toobar or simply type a[1. The second example is using an as so far undeclared variable b assigning the element with index 3 (the fourth element) the value 25. As b does not exists Mathcad creates a vector with 4 elements, filling the unreferenced elements with 0. This is what Mathcad would have done in your case, but as x and y where undefined, it failed and f was undefined, too.
We have done that, so far.
z would be still dependent of x and y. What you want is to first define x and y as fumction of parameter t and then define z(t):=f(x(t),y(t)), right?
I did it my sheet, but named the function f2 instead of z.
You cannot tell Mathcad how it should calculate the derivation, but you can do it yourself (in MC) both ways and compare the results. Mathcad may not show the two results simplified and written the same way and sometimes its hard to verify the identity. Especially when it comes to sin, cos or logarithms.
See the attached worksheet for one way to do it. Hope it helps.
You should see it if you click directly on the derivative, not just anywhere in the region.
You know you should write dz(x,y)/dx, etc. !?
I've only just noticed that Homework section of the Forum. I should have probably posted there as I'm not an Engineer. Sorry . I'm an undergraduate (mature-so I'm called at 21+ ) student learning to use Mathcad.
Thank you for your very helpful replies
Andy
No need to worry about, your question is in good hands here at "Calculus", too. There's no "engineers only" section anyway (otherwise I would have to stay away, too ;-).
The "Math Homework" section used to be named more appropriate "Educational Applications" in the old collab forum before PTC merged it in a very nonprofessional way into this community. You would meet there the same people as here anyway 🙂
Good luck and fun using and exploring Mathcad!
Cheers!
