I am fairly new to Mathcad and I am trying to do the following from the data sheet. I need to make both of these plots and haven't got a clue where to start. If anyone can help it would be REALLY appreciated.
The problem is most likely that Mathcad doesn't know what "p" is. Place the cursor immediately after the p, and hit <Ctrl> g. It should change to the Greek letter pi. However, as Adrien says, a better way of doing it is to type "deg" into the units placeholder.
As there is no (obvious) way to add a second Y-axis to the plot,
There is no way to add a second axis in Prime.
Thanks guys for all your help, its been much appreciated. I think I'm pretty much there thanks to you guys.
Is there a way to you can add ta second axis in Mathcad 15?
right click on the plot, select format:
this will bring up a pop-up window
check the "Enable secondary Y axis" box.
