I can't get my function plotted, it tells me that i have to replace the complex and NaNs by real numbers .. My function is not complex, so what is wrong?
See attacted file
Great!
What did you do, or what does it mean? (x:=0m,10cm..10m)
It's a range variable. Adding the unit (m) does the trick 😉
I think it is not a trick but an error of Mathcad Prime. Sometimes (or always?) we cannot use QuickPlot technology in Mathcad Prime. We must insert a range variable - x:=0m,1mm..10m for example.
The trick is to circumvent that error 😉
But I agree its a bug/error. Will it be corrected in Prime3?
It was a picture from Prime 3.
In Mathcad 15 all is ok:
I know!
I have pointed this bug to PTC but I think the QuickPlot Techology (without a range Variable) is not for Prime.
See attacted file
John, do you have a correct answer?
