Hi I'm wondering what's wrong with my graph
moment diagram is not appearing.. Can u help
me identify how am i going to fix this.
Pls see attached, thanks in advance
Joseph
I think it will be better to put your question not only here but on the Mathcad branch of this forum.
Try changing the range of values for the variable "x":
Thanks vladimir for the solution
You're welcome. I attached the edited file to the message.
