Hi guys,
Pls help me with my problem, formula is given above
and i make it a function to graph it but ellipse is not closed.
Thanks in advance
Try like this,
you need to consider both solutions for the complete picture.
range variable x: -6,5.9;6 still leaves a small , but noticeable gap.
Andy
Thank you very much for your kind reply.
Also, you can try the following:
