Prime 3.0, correct format for NaN?
dsochor
I am a recent convert from MathCad 15 to Prime 3.0. In the attached Prime 3.0 worksheet, what is the correct formatting for stating if a variable is not an answer (NaN) to set a variable to one value, and if it is an answer to set it to another variable?
You do it the same way in Prime as you did in Mathcad - you use the built-in boolean function IsNaN(...).
dsochor
As always, thank you Werner.
athurin
Alternatively :
kkkk := 2 - IsNaN(k.FBeam1)
Adrien Thurin wrote:
Alternatively :
Or as a vector index, so you still have a free choice which value to assign in either case:
