Problem with Given-Find cycles using vectors
bamaya
Hello, I'm having a problem solving a Given Find cycle with vectors. I'm trying to plot T vs. X1 and T vs. Y1.
Mathcad gives me back always the same value for Y1 and incorrect values for T. Using minerr I don't get better results. Can someone tell me what I'm doing wrong?
RichardJ
(To:bamaya)
See the attached worksheet.
Note that the default value for the origin of arrays in Mathcad is 0, not 1.
RichardJ
(To:bamaya)
Thanks for the answer. It works fine. I didn't know about the vectorize operator!
