Programming Mathcad problems
pblbailey
To Whom It May Concern,
I was playing with lotto numbers and just trying to come up with a simple algorithm to just find the frequency of numbers based on digit placement...not on the entire number base, but on that digits' number span. I think I am having problems with values transferring from programmed functions I wrote that are not going into the next algorithm for calculation. My attached program is a little junky I know, because I was trying to troubleshoot the problem, but that is another thing...I couldn't get values to output in their troubleshooter either. Not sure how that works either..HELP!
Thanks for any help you can give
Bruce
I don't want to troubleshoot the programming. To check any efforts you can use this simple worksheet for true results.
