Programming
bderouiche
Programming
Hi everyone,
Can anyone help me to program this plz:
Knowing all of: Fi, a1,a2,a3, gama, beta,delta t and u0, 0 and ü0
Thank you
Bily
(To:bderouiche)
Something like this?
Note that I assumed you made errors which I 'corrected' in:
- the first bullet. Fi+1 = Fi+...
- the third and fourth bullets. ui+1 = ... instead of ul+1=
7 REPLIES 7
(To:bderouiche)
i have this issue which says that origin is not defined
im using mathcad prime 3.1
and if i do origin=0 i'll have (i) is undefined
and by the way i need all value of u, u' and u'' not only F
thanks
(To:bderouiche)
Its ORIGIN, not origin, that is a defined item in Mathcad.
I don't see an undefined i.
If you want more results, then return all of them in a vector or matrix, like e.g. ( F u u' u'' ).
Thank you for your reply it's really helpful but i still got pbm as shown, it doesn't show me the value !
what have i done wrong? or what should i do to show the result?
thank you
It would be really helpful if you wouldn't just post pics but attach sheet.
The pics are important though if you use Prime 3.1, as many of us didn't bother to upgrade and can't read P3.1 files, only P3.0 ones - yes PTC made it incompatible.
In your case you may go to ribbon "Matrices/Table" and in "Result Format" uncheck "Collapse Nested Matrices".
A better idea might be to assign the result to a variable
Res:=TimeStep(3)
and then, to see the vector u, you may type Res ctrl-shift-c 1  =
or as an alternative you may assign teh result to a 1 x 3 matrix rightaway
[ F  u  û] := TimeStep(3)
And then F=..  u=...   ...
WE
RichardJ
(To:bderouiche)
You do not specify how to calculate Fi+1 from Fi
i have all Fi which is a matrice
