Hi
Anyone knows if it is possible to return a nested matrix from a custom function i.e. I want to build a function that has a return value similar like the built in LU(M) function.
You mean from a user DLL?
Not even passing a nested matrix to a User DLL function is officially supported, refer to:Pass/access nested array in user dll. And there is more to be found in this forum, although many attachments of the good old forum are lost..
Sure thats possible. You can return whatever you can create. But lu(M) does not return a nested matrix but three matrices which are augmented in a single big matrix.
