Rotaional Speed to Overcome Shrink Fit
ptc-4961564
Hi Folks,
First time posting on this forum. I am a novice Mathcad user. I have Prime 3.0 and am having problems with a solve block. I suspect the problem is how I have the worksheet set up.
I have two equations for the maximum tangential stress on a hub connected to a shaft. First equation is stress due to press fit. Second equation is stress induced by rotation of hub. I am trying to solve for the rotational speed where the stress from the shrink fit is overcome.
I have solved this problem by hand. Now I am trying to have Mathcad save me the time required to rearrange equations.
I would appreciate any advice you could provide. I have attached the file.
Bill
RichardJ
(To:ptc-4961564)
You need to make sigma_tmaxr a function of w.
I also changed the units of the result for you.
RichardJ
(To:ptc-4961564)
ptc-4961564
(To:RichardJ)
Thank you Richard for your prompt reply and the rework on my calc!
Bill
