Shear force diagram and Bending moment diagram
kkhaikrut
Sorry ,If i'm use wrong English because i'm not good English.
My name is Kitkaseam. I'm studying in Civil Engineering .
I need help on a Program of Mathcad prime 2.0 to find Shear force diagram and Bending moment diagram have any Pointload and any Uniformload.
I can do general format but i can't do any pointload and any uniformload .I tried to do it many times, but failed. If you have program or have suggestions. You can tell please.
Thanks very much.
Kikaseam
Send please your Prime sheet.
I can find Reaction but i can't find Shear force diagram and Bending moment diagram
There are quite a few beam worksheets that we use. See if this helps any. You're best bet is to define the shear, moment, and deflection equations. Or you start with the shear and integrate to get moment and deflection.
Thanks very much for suggestions and work sheet. I will try
