I have an two variable equation. I want to use one of the two variables as a range variable, and I need to solve the equation for the second variable. I want to use the solution later as a function of the range variable.
Very simplified example of equation I want to solve: R-T
I want to use R as a range variable, but get the solution for T for use later in the work sheet
I have attached an example of the two variable equation. In this example, I solved for D but R is defined. I want to use R as a range variable and use the solution D as a function of that range variable.
