Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
On 10/19/2009 11:35:18 AM, schneidrax wrote: >Both r and n(r) are real and >positive. Is there a better >way to remove the symbolic >csgn function? > >________________________________
That would be disaster if you mean remove from the symbolic. It is a simple but scalar math function and as such enables many functions to have their full mathematical scalar meaning. Would you also remove sgn ?
On 10/19/2009 4:52:44 PM, schneidrax wrote: >On 10/19/2009 4:32:02 PM, philipoakley >wrote: >>So you need a way of saying: >>assume n(r) > 0 >>Philip Oakley > >Yep.
The maple way is algsubs, but hard to access from mathcad. Try the last simplify, but use with careful the symbolic keyword.
On 10/19/2009 8:23:50 PM, schneidrax wrote: >Thanks, Alvaro. Works like a charm. _______________________
You can attack more efficiently in the sense of csgn(z) Why do you call the built-in 'z', why do you call 'x' ? ... z as reserved to the complex domain, universally by the "mathematical community" ?
Whst version of Mathcad? It's better to post actual Mathcad files than just pictures. I don't really like retyping a lot of things -- I make too many errors that way.
Generally when working with the symbolic processor I just don't use the function notation. Even if n is a function of r I leave it as just n rather than n(r). Then there is no problem assuming n>0.
This fails to differentiate properly using the standard differentiation operator, but I either use subst to restore the explicit functional notation first, or (more commonly) use the TotDeriv function from my Jacobian etc. worksheet. __________________ � � � � Tom Gutman
