I am using mathcad prime 10.0 and have created a program to solve for F_rated. I then want reference this program in a for loop, however it says the inputs to the function must be integers. Outside the for loop the equation works fine so I am a bit confused.
Mathcad Prime is unable to distinguish between function Frated and variable Frated.
Simple change the name of the function.
Here is a screen shot if that is helpful.
Thank you so much for the help Terry, that did the Trick!
On the side,
Matrix indices start at zero bty default and your loops for "i" and "j" start at 1 which gives a row and column of zeros in matrix F.
In menu Calculation | Worksheet Options | Origin you can set the first index to 1.
Ah seems as though I missed that as well, thanks finding that error too! I appreciate all the help!
