Translating a mathcad script from book to worksheet
thefinepotato
2-Guest
Hi!
I am trying to complete an assignment however I have difficulties translating a Mathcad code from the book to the worksheet, I have never used Mathcad before so it would be great if someone can show where I am going wrong or even better if someone can translate it onto a Mathcad file for me!
I do require this quite soon so any help with be greatly appreciated.
Thank you very much in advance!
See attached  (but next time attach your own worksheet attempt, even if it contains errors - it is generally easier for us to modify an existing attempt than to construct a worksheet from scratch).
Alan
NB You didn't say what version of Mathcad you are using.  The attached is Mathcad 15.
(To:thefinepotato)
We're NOT here to do your homework for you. You will have to make a start, and attach your Mathcad worksheet if you run into problems. Please be sure to indicate what exactly the problem is, in such a case.
The mathcad itself isn't for homework!
I just want to use it so I can play around with it to see how the graphs would look.
We aren't taught to use mathcad but I found it in the university software list and I was interested in it and if I could use it in my assignments.
I agree with Luc, fire up that computer and start typing!
