Hi, I had the same problem...I was very confused but I found the solution... the problem is the format of the image..if you used "jpg" it isn't problem but if you used "bmp",like my case, you can have two or more formats of "bmp" file. You should be care with this. You should use "256 colours" format, you can see this by opnening the file in "paint" and save as "type of file 256 colours". I hope that these comments are useful.
