Updating initial conditions for solve block
AliErbay
Hello ,
I have two equations , two unknowns and one freed parameter.
So solve block finds solutions for two unknowns with respect to changing parameter in the equations.
What i want to do is updating initial guesses for solve block after each solution ( taking the previous solution and setting them initial guess )
I know this will not change anything for this system but i need to apply this continuation method to a very complex and nonlinear set of equations which is very sensitive to initial guesses ( I dont have only one solution depending on initial guesses i have another solutions also )
So i want to be sure that i am following a one branch of solutions by changing initial guesses. In the end i should be able to get a graph between freed parameter and solutions.
One possibility attached.
Alan
Alan
Thank you
It helped a lot
I was able to follow two branch of different solutions in the same region
MikeArmstrong
(To:AlanStevens)
Superb Alan.
Mike
