Value of Sin (Theta)
lsingh-2
Hi All,
I am not sure why the value of Sin (Theta) is not coming out correct in Prime 2.0 (see attached). The calculator value is 0.342. Any advice?
LS
RichardJ
(To:lsingh-2)
The default unit for angle is radians, not degrees. Try Theta:=20*deg
