On 5/27/2009 2:05:36 AM, Desiv5 wrote:
== -1. As you can see in the attached file, the plot will display only the left side of the graph, although there is also a right side, symetrical placed to "0"... I can even read the values also on the right graph side with the Trace function, but why it's not displayed?
== -2. I'm trying to display in my graph the plot of several varants of the force-function: Fk(L,10mm), Fk(L,12mm), Fk(L,15mm)... but Mathcad doesn't appear to be able to calculate them, because the calculation starts and never ends (light-bulb is blinking forever) and I have to kill the Mathcad task in taskmanager to stop it... Am I doing something wrong again? As you see, the function is not complex at all, so it should not be a problem for Mathcad to calculate it...
Same root cause - there is a singularity at L = 0 mm. Interestingly, if you select symbols on the trace, the rhs symbols show even though the line doesn't.
Alter the range variable, or put a condition in Fk, to skip 0.
Your original worksheet is fine in Mathcad 11.
Stuart
