I am looking for a mathcad calculation sheet, based for example on the theory of elastic stability by Timoshenko, to determine buckling capability of a column loaded by an eccentric compressive load.
Hi Daniel,
Please find some examples in the attachment (worksheets for Mathcad 14/15).
Hi Vlad.,
Thanks a lot for your answer.
However, those sheets do not allow to account for some eccentricity in the load application and this is my major concern.
