curve area and interp function help
uclphd
Wish to calculate the area under a curve from a set of data, but having difficulty.
Also wish to interpolate the imported data using interp function but I get errors.
Attached is the file which I hope explains.
Many Thanks,
Omar
16 REPLIES 16
StuartBruff
23-Emerald II
(To:uclphd)
Omar,
Your file doesn't appear to contain any data?
Stuart
Data for the plot ???
That's strange.
the previous attachment is mathcad11
the attached file is just the data in a newer version of matcad. Any joy seeing the data file B?
uclphd
(To:uclphd)
Just tried opening that B file, no data as you say. I have no idea why the data dissapears when attached here.
uclphd
(To:uclphd)
Ah, I used the import wizrd. Does it require to read the file from a location on my computer?
In which case how do I make the data I import "static" on the mathcad page so i can attach here?
StuartBruff
23-Emerald II
(To:uclphd)
Can you post the file containing the data?
Hi Stuart, attached is the excell csv file with data I used for data set B in mathcad file.
Any luck?
StuartBruff
23-Emerald II
(To:uclphd)
Any luck?
Don't know, Omar ... does the attached help?
Stuart
Many thanks Stuart, that helps a lot. I will study it.
Omar
StuartBruff
23-Emerald II
(To:uclphd)
Is the attached of any help in using the interp function?
Stuart
Thanks for that Stuart, i will look through. Iv'e posted the B csv data file, so if you can look at the original problem I was having that would be great. Thank you.
Omar
MikeArmstrong
(To:uclphd)
I have no idea if this is correct, but thought I maze well post it so I can learn
Have you got the area calculated?
Mike
Cheers Mike, I will study it. Definitely more than one way to skin a cat on mathcad!
Omar
MikeArmstrong
(To:uclphd)
Dan posted a link to a similar problem a while back, I'll try and dig it out.
Mike
Thanks Mike, much appreciated.
Omar
MikeArmstrong
(To:uclphd)
Here is the link to the thread I was talking about, might help.
http://communities.ptc.com/message/154243#154243
Mike
