The complaint is about m not being a vector. The construct x<i>←y requires that y be a vector, and that, if x is an array, it have the same number of rows as x. In MC11 the error trace seems to be broken for this case.
In MC14 you never execute the assignment, as NaN does not compare equal to NaN. You must use the IsNaN function to test for NaNs. However MC14 does tolerate the assignment of a scalar, treating it as a one element vector.
To fix it:
In MC11: use an array constructor to assign the one element vector (m) rather than the scalar m.
In MC14: change the Mm=NaN to IsNaN(Mm). This should be done in MC11, but is not necessary there.
__________________
� � � � Tom Gutman
