Thanks in advance.
The answer should be:infinite
(e^B)^C=e^(B*C)
in your case B=-iax and C=i/(ax), so B*C=1
That simplifies your equation to e-e=0
any value of x will do, as long as it's unqual to 0.
(e^B)^C=e^(B*C)
As we are obviously dealing with complex numbers, thats only true if C is an integer! Otherwise any complex number with magnitude e^(B*C) and argument any integer multiple of C*2*pi is result. If C is irrational thats even an infinte number of results.
But as the question is about solving that equation, your solution is valid nonetheless: if a is unequal to zero, x can be any value different from zero, otherwise x is undefined.
